1 minute ago, Oshino Shinobu said:
PCIe lanes are based on the chipset with AMD, not the CPU. The amount of PCIe lanes available will depend on the chipset you use.
Ok how do I know what chipset im using? The board is a Gigabyte GA-MA69-S3H
Breaking things 1 day at a time
https://linustechtips.com/topic/567591-how-many-pci-e-lanes/#findComment-7454946
AMD 690G Northbridge and ATI SB600 Southbridge. For PCIe lanes, only the 690G matters, which has 24 PCIe lanes.
https://linustechtips.com/topic/567591-how-many-pci-e-lanes/#findComment-7454965
OK awesome. Just checking to make sure I can put what stuff in the expansion slots
https://linustechtips.com/topic/567591-how-many-pci-e-lanes/#findComment-7454988
Just now, airdeano said:
i also believe that is a 2.0 x16 version. so any devices asking for 3.0 x16 (SSDs) might have hampered results.
Yeah no to the SSD's. This build is literallly all use dparts, with better price to proformance than scrapyard wars because I spend $0
https://linustechtips.com/topic/567591-how-many-pci-e-lanes/#findComment-7455082
