an antec true power classic 750w is a great quality psu and will let you have good room for upgrading http://pcpartpicker.com/part/antec-power-supply-tp750c
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/566980-psu-for-my-build/#findComment-7448126
2 minutes ago, JFischer00 said:
I'm upgrading to an i5-4590 and a GTX 960. I'm also thinking of getting a new PSU. Right now, I have a CX430M. I don't plan on overclocking the 960. So two questions: should I upgrade the PSU and if so, which one should I get?
you're good but i suggest getting a new one when you can afford it and use the CX as a spare
this is because the CX series is not the most reliable psu out there
and when a psu dies, theres a possibility it might take out other components with it, like the cpu, gpu or motherboard
but its totally fine if you wanna continue using yours, its not THAT bad, its just not the best
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/566980-psu-for-my-build/#findComment-7448131
You're fine
https://linustechtips.com/topic/566980-psu-for-my-build/#findComment-7448863
