Converting an R/C car into single-rotor drone?!
Solved by Moonzy,
5 minutes ago, anandgeforce said:I've got an R/C car that doesn't do good... Can I just remove the plastic chassis, and wheels, and then fix a rotor to the rear axle (one side), to have a functioning drone? The front axle can be used for left/right flaps...
the motors for RC cars probably arent made for low torque, high speed situations that are meant to be used for propellers
and then theres aerodynamics
and keeping the aircraft from tilting, spinning, and turning without control requires sensors and a microcontroller
simply speaking, its not as cut dry as just attaching rotors to the end of the car
