Cooler for i5 6600K
Hi,
This will be my first pc and I need help picking a cpu cooler. What I am looking for is a)looks b)performance c)noise. Price it not my biggest concern sine I am not planning to upgrade this pc for some time, I want to something good to start with and don't worry in the future. PC will be mostly used for gaming and photoshop.
My case will be NZXT s340 and I am going for a black and white build: http://pcpartpicker.com/p/Rntn3C (ram will be white). s340's only frittered intakes are at front and supports up to 240mm rads. This will make my cpu cooler but my gpu hotter I believe. Or I can get a 140mm exhaust on the top. Which one would you recommend?
I read a ton about 240mm coolers but all has a weak spot. Please give me some ideas. Here are my thoughts: (are they valid?)
Kraken x61: Amazing performance/noise but horrible CAM software, which might cause terrible problems
Corsair h110i: Good performance, but noisy
DEEPCOOL Gamer Storm CAPTAIN 240 white: OK performance, amazing looks but not much reviews online
Cooler master neptue: OK performance but very silent
Or am I better with a white air cooler (like Phanteks PH-TC12DX) in order to have lower noise(?), cooler intake and safe from leakage?
any help is greatly appreciated
Corsair H100i GTX is one of the top water coolers out there, you can just switch the fans out if they are too noisy.  But you get what you pay for. About $110 I think.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
H110 GTX! It's brill, but I've never tried it out on stock fans, Noctuas FTW
i5-6600k @ 4.9Ghz | Corsair H110i GTX + 2 x Noctua NF-A14's | ASUS Maximus VIII Ranger |
Corsair Venegance DDR4 8GB | ASUS GTX 970 Strix |Samsung 840 EVO 240GB + 1TB HDD |
Corsair RM850 | NZXT H440 Black | 2 x Noctua NF-F12 + Corsair AF-140
So you think having using it as intake is worth higher gpu temps?
A front mounted AIO isn't going to put any more hot air into your system than any air cooler would.
No cooler is maintenance free, because you need to clean them regardless of what type you get, but if it's something you want to install and not worry about I would stick with one of the better air coolers...  Something along the quality of the nh-d14.  You aren't really losing any cooling performance with one either, because something like that typically keeps up with most 240 aio's.
my work in progress
i5 6600k  //  16gb g.skill ddr4 3000  //  evga gtx 980
custom water loop
I hear about Noctua all the time but they are not an option for me (brown fans). Any other recommendation?
Oh, I was only commenting on water cooling cos you were considering only water cooling from your list.  A decent air cooler is much cheaper and performs equally as well as mid-range water coolers and frees up more fan space.  Chuck an intake at the front and have the back exhaust.  Leave the top empty.
I'm not keen on the design either, but I just use 2 fans in pull position on the top of the rad, and my case doesn't support push pull at the top so it doesn't matter for me
Only thing is it just looks ridiculous in my opinion
dark rock pro 3
-sigh- feeling like I'm being too negative lately
3 minutes ago, Moonzy said:
dark rock pro 3
would have both it if it was white :(
spray paint the top aluminum, its there for the looks anyway xD
As for what performance the H110 gives, Im running my 6600k at 4.9Ghz at 1.35v at around 65C at full load with two fans that are silent at all times
