If you do not use USB PCIE CARD, the system does not support hot swap it?
I'm ready to set up unRAID system, but can not increase ITX motherboard using USB device display card, there is no other way to make unRAID virtual machine supports hot-swap devices。
1 minute ago, Im Herzen.ZY said:
Thank you for your helpxDxDxD
No problem :)
I hope you got to the part where someone said
Quote
"Almost* all consumer level SATA controllers support hot swapping.
They're not SATA controllers if they don't, it's part of the basic SATA spec.
* In RAID mode this is much less reliable, since then the controller is free to do what ever the fuck it likes and has no need to comply with AHCI. "
1 minute ago, Bajantechnician said:
No problem :)
Quote
xD
