no. just no. save up more money because there is no value what so ever at that price, maybe you can find something used but thats to litle to make a decent PC, not with perifiirals and monitor
Builds:
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7426471
This really isn't worth it but I tried to go as low as I could. Your friend really needs to save up at least another 200 bucks.
PCPartPicker part list: http://pcpartpicker.com/p/7PpgD3
Price breakdown by merchant: http://pcpartpicker.com/p/7PpgD3/by_merchant/
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($89.99 @ Micro Center)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($25.75 @ OutletPC)
Motherboard: ASRock 970M PRO3 Micro ATX AM3+/AM3 Motherboard  ($41.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory  ($38.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($65.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 750 Ti 2GB Video Card  ($99.99 @ NCIX US)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($22.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($87.95 @ OutletPC)
Monitor: AOC e2050Swd 60Hz 19.5" Monitor  ($69.99 @ Micro Center)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($24.99 @ Newegg)
Headphones: Logitech G230 Headset  ($34.99 @ Micro Center)
Total: $643.58
Generated by PCPartPicker 2016-03-13 17:49 EDT-0400
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7426497
2 hours ago, Tiki said:
http://pcpartpicker.com/p/TTm8WZ there red theme, can add more fans. And buy the Microsoftkey of the sub reddit page for 25$
Nice one, but i would upgrade the power supply since i've heard mostly negative things about the cx series. Probably get a silverstone one or one of those from cooler master with 5 year warranties or so
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7427983
$1097:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($189.99 @ SuperBiiz)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  ($54.99 @ Amazon)
Memory: G.Skill Aegis 16GB (2 x 8GB) DDR4-2133 Memory  ($58.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($57.99 @ Newegg)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($309.99 @ SuperBiiz)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  ($64.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($48.99 @ NCIX US)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($89.99 @ NCIX US)
Case Fan: NZXT RF-FN142-RB 50.0 CFM 140mm  Fan  ($8.99 @ NZXT)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor  ($120.98 @ Newegg)
Keyboard: Logitech K120 Wired Standard Keyboard  ($11.99 @ SuperBiiz)
Headphones: ROCCAT Kave XTD Stereo Desert Strike Headset  ($39.89 @ Amazon)
Total: $1057.77
Generated by PCPartPicker 2016-03-13 23:53 EDT-0400
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7428095
location and what you plan to use it for?
You know how it is, the cow goes "moo", the dog goes "woof" and the gamer goes "The PvP is unbalanced."
Personal Computer: CPU: i7-4790 Mobo: Asrock Z97 Extreme6 Graphics Card: MSI R9-380  Memory: 16GB (8GB x2) G. Skill Sniper Gaming Series PSU: Apevia Warlock 750W Case: NZXT Phantom 410 Series Storage: 240GB SSD (OS) 3TB HDD (data and such) 500 GB SSD (Movies and Large Data Transfers (I'm constantly moving this one around to other computers))
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430350
this, and get an OS from somewhere for about 20~30US
PCPartPicker part list: http://pcpartpicker.com/p/f8V63C
Price breakdown by merchant: http://pcpartpicker.com/p/f8V63C/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($119.99 @ SuperBiiz)
Motherboard: MSI B150 Gaming M3 ATX LGA1151 Motherboard  ($94.99 @ Amazon)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($35.88 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: Asus GeForce GTX 950 2GB Video Card  ($144.99 @ Micro Center)
Case: Corsair 200R ATX Mid Tower Case  ($49.99 @ Micro Center)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($53.98 @ Newegg)
Monitor: Asus VS228T-P 60Hz 21.5" Monitor  ($98.88 @ Amazon)
Mouse: Logitech B100 Wired Optical Mouse  ($6.80 @ NCIX US)
Total: $667.38
Generated by PCPartPicker 2016-03-14 12:50 EDT-0400
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430389
2 minutes ago, yoggie123 said:
If you have another computer, you can get a license of windows 10 of kinguin for <$30 and then you can put that money you saved towards a better graphics card. If that's what you want, though it might be worth it to save up a bit longer to get something like an R9 380. Also it's worth noting there's a compatibility issue with your case and your motherboard- Case has usb 3 and your motherboard doesn't support it.
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430445
6 minutes ago, yoggie123 said:
This looks pretty solid, though I would say get your windows license somewhere cheap like Kinguin.net and take out the optical drive, then you can afford an SSD if you want.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430446
  Hide contents
Total: $667.38
9 minutes ago, yoggie123 said:
First will work better for more CPU intensive tasks, second will be more gaming focused. Both good choices.
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430464
  Hide contents
Total: $667.38
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($44.99 @ Micro Center)
Memory: Avexir Budget Series 8GB (1 x 8GB) DDR4-2133 Memory  ($26.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Video Card: XFX Radeon R9 380X 4GB DD XXX OC Video Card  ($203.98 @ Newegg)
Case: Xion XON-310_BK MicroATX Mid Tower Case  ($22.98 @ Newegg)
Total: $642.67
Generated by PCPartPicker 2016-03-14 13:02 EDT-0400
Sorry but I just 1-upped you. @yoggie123 Good CPU + great graphics card.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430465
i went with an ATX board for the looks, coz i would mind about it xD
definitely go for your build if he wants more performance and not care about looks
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430481
5 minutes ago, yoggie123 said:
is it worth it cause the 6 core fx m,ay be weaker in corews but has more cores in genral
IMPORTANT EDIT: the i3 cant be OC-ed now, but this test should give a baseline answer
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430493
4 minutes ago, TheRandomness said:
oh yea, you shouldnt use unvalidated ram with skylake, ive seen enough cases of people using unvalidated ram and having their computer not boot
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430500
Invalidated RAM sounds like bullshit. My thought train: DDR4 + Skylake = fine. I need proof :P
USEFUL LINKS:
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430516
ive dealt with 2 people so far with unvalidated ram not booting and they swapped to kingston hyper x black and it worked
proof... im lazy to dig for the thread in this forum... but its a known issue
https://linustechtips.com/topic/564946-i-need-a-pc-build/#findComment-7430522
