H100i replace cooler or change fans?
Solved by BurstSMG,
You can buy a couple good 120mm fans such as the SP120 and replace the ones that are already on there easily. I really wouldn't reccomend downgrading from an H100i, unless you get this: http://noctua.at/en/nh-d15.html
Featured Topics
redywox ·
Posted in New Builds and Planning2 -
Mahbub ·
Posted in General Discussion3 -
da na ·
Posted in Photography and Videography2 -
1
2
6
2
SillyFrog44 ·
Posted in Graphics Cards5
