How to get numlock to stay on when starting pc
Roboslash1
Hi.
I am running windows 10 and I use a pin code to log in. However everytime I start the computer, i have to click the num lock to make it possible to use it. How can I toggle it so that it is on when i start windows? I remember before I reset it, the numlock was on from day one, without having me to change it.
Thanks,
Felix
Desktop: Processor - Intel Core i7 5820K   Motherboard - Gigabyte GA-X99-UD3   RAM - Crucial Ballistix Sport 16GB 2400MHz DDR4   GPU - Gigabyte GeForce 980 Ti G1 Gaming 6GB Case - Fractal Design R4 Window   Storage - x1 WD Green 1TB, x1 WD Green 2TB, x1 Samsung 850EVO 120GB, x1 Kingston SSDNow 120GB  PSU - Cooler Master B700 (700W)   Displays - x1 Dell E2214H, x2 Dell 1908FP-BLK   Cooling - Noctua NH-D14 SE2011
Keyboard - Razer Blackwidow Expert 2014   Mouse - Razer Deathaddder 2013   Speakers - Logitech Z906 5.1 OS - Windows 10 Pro   Headphones - Steelseries 9H, Sennheiser Momentum
on my laptop it's kinda non-issue because I press NumLock and the PIN window pops, then I use the numpad keys to enter it
12 minutes ago, Omon_Ra said:
Check your BIOS. There's usually an 'Enable Num-Lock on Boot' option somewhere in there.
I'm not entirely sure, but I think W10 overrides it when it's set to PIN login
the BIOS setting should be Boot up Num Lock [enabled] / [disabled]
there are two methods of forcing NumLock ON
  1. let W10 go to login screen,press numlock and then press the power button on the PC/laptop/watever; at the next boot NumLock should be on
  2. registry edit: find HKEY_USERS\.DEFAULT\Control Panel\Keyboard edit string value named InitialKeyboardIndicators to 80000002 and reboot
set it in local policy if windows is turning it off....
not available on W10 Home, only from PRO upwards
sorry to hear that.
12 minutes ago, RodJames said:
sorry to hear that.
we can only cry and hope o.O
