hey guys im planning to buy a okey PC
but im kinda new to this after few days searching i found few things i am willing to buy
please tell me after assembling this stuffs will i be able to run the PC or screw up
Intel Core i5-6500 3.2GHz Quad-Core Processor
Gigabyte GA-B150M-D3H Micro ATX LGA1151 Motherboard
Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory
Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Driv
Gigabyte GeForce GTX 750 Ti 4GB Video Card
Cooler Master Storm Stryker (White) ATX Full Tower Case ( Dont care about cost always cared for the look )
Corsair VS 550W ATX Power Supply
Questions
__________
1. will my power supply enough for this ?
2. should i go with liquid cooling if so which one ?
3 . any other ideas ?
https://linustechtips.com/topic/564679-excited-for-new-pc-help/
1. It's bad quality. I'd probably go for a 500B instead.
2. No. Just use the stock cooler.
3. Bad PSU and bad SSD. Can I have a budget? Currency and location would be appreciated.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/564679-excited-for-new-pc-help/#findComment-7423827
Budget? Country? Don't buy that psu and ssd, they're both crap
I5 4470     -     Cooler Master Hyper 212 evo    -    Asus Strix GTX960    -    12Gb ram    -    Adata SP600 128Gb    -    Seagate 2Tb    -    AsRock Fatal1ty B85 Killer    -    Seasonic M12II EVO 520
IN WIN 703    -     Dell P2414H    -    LG Flatron M197WDP    -    CMSTORM Quickfire XT with MX blue's    -    Logitech  G502
Quote
"To finish first, you first have to finish"
https://linustechtips.com/topic/564679-excited-for-new-pc-help/#findComment-7423835
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
processor: try getting an unlocked processor, you will benefit a whole lot by just paying a bit more if you're into overclocking
motherboard: if you opt for overclocking processor, get an overclocking board
ram: good choice for future expansion, but bad choice if you plan on using 1 stick of ram long term, dual channel is always better
ssd: bad choice, the v300 series have a bad reputation for being under-performing, i suggest going with a samsung 850 evo
HDD: no problems there
GPU: 750Ti is a low end card, if anything, i would suggest you forgo the i5 and opt for an i3 instead and get a better gpu, and i5 and 750Ti would be unbalanced
unless you plan to upgrade the gpu in the future after pascal/polaris launched, then 750ti and i5 is fine
case: personal preference, no comment
psu: get a better one, 500W~600W is enough provided you get a reliable one
1. Wattage yes, reliability no
2. no, unless you plan to overclock
3. as mentioned above
additional comment: whats your budget? try giving us a budget and we'll see what we can come up with
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/564679-excited-for-new-pc-help/#findComment-7423919
Thanks for helping and no im not into overclocking things which ones you suggest ?
i mean in the case of a balanced combo of processor and graphic card ?
and which PSU ?
https://linustechtips.com/topic/564679-excited-for-new-pc-help/#findComment-7424150
so you're not planning to upgrade your gpu if u were to go with 750 ti?
i suggest going i3 6100 + something from AMD for mid range, but i gotta know your budget to decide
https://linustechtips.com/topic/564679-excited-for-new-pc-help/#findComment-7424170
4 hours ago, xXwhiplashXx said:
you sure 2.7 ghz enough for gaming ?
i dont know much about those but i think higher is better ?
CPU bottleneck isnt an issue nowadays, yes the 6600 is better than the 6400, and you can get that if you have the budget
i myself got a 6600 instead of a 6400 xD
https://linustechtips.com/topic/564679-excited-for-new-pc-help/#findComment-7429405
