Verizon and locked bootloaders
Solved by Bajantechnician,
5 minutes ago, kurahk7 said:My upgrade is available early so I'll be going to the Verizon store tomorrow to upgrade to the S7. Hearing that Verizon phones have locked bootloaders that are not unlockable, is it true that you won't be able to flash to any rom of your choice with any Verizon phone?
correct.
also, if you flash custom roms even from other providers, it should 99% of the time void the warranty
