PLEASE HELP
Go to solution Solved by Lolucoca,
@DirtyBert I know why you have those lags. You only have 1GB Of RAM allocated to minecraft which it is using completely. To change that, you have to edit your launcher profile. Click "edit profile".
Then, you have to change two parameters. -Xmx and -Xmn. -Xmx is the maximum amount of RAM minecraft is allowed to use and -Xmn is the minimum amount.
If you have 4GB of RAM, I would not change something since 4GB is not very much. If you have 8GB, you can do this: -Xmx4G -Xmn1G. If you got 16GB of RAM, you can allocate 8GB by changing it to -Xmx8G -Xmn1G. As you see, I allocated 10GB maximum and 8GB minimum. Just change those two parameters. Do not add them manually. They are somewhere.
hey guys
i have recently built a PC (in 2015) with a  GeForce GTX 960 and an intel i5 and my minecraft is sometimes not loading a world or getting really high frame rates like 500fps then droping down to 15fps and sometime crashing i have vsync turned off on my GPU and my minecraft and when i go on servers it just gets really low FPS (20 30)
i know minecraft is a little kids game but i really need help becuase its the only game i have atm
Thanks and if you need any more info just ask
https://linustechtips.com/topic/563497-please-help/
3 minutes ago, DirtyBert said:
hey guys
i know close to nothing about minecraft but my guess is you modded it?
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/563497-please-help/#findComment-7410872
i7 6700k - 32GB DDR4-2133 - GTX 980
https://linustechtips.com/topic/563497-please-help/#findComment-7410921
the problem to anything minecraft related :
IF YOU WANT ME TO REPLY TO YOU, QUOTE MY POST.
Fire Strike Score
5820K @ 4.8GHZ - 1.25v / Uncore @ 4.5GHZ - 1.2v / 3000MHZ G.skill 32GB Quad Channel / Asus Rampage V Extreme / 950 Pro Nvme / Sound Blaster ZxR  / 980 TI / Windows 7
https://linustechtips.com/topic/563497-please-help/#findComment-7410957
i dont know what im doing wrong?, nothing is working
https://linustechtips.com/topic/563497-please-help/#findComment-7417261
