I have an MSI motherboard, and couldn't find a program for MSI mobos that controls the fans, like Fan Xpert.
Does MSI have one and if so, where would I find it?
Intel i7 6700K | MSI Krait Z170A MSI GTX 980 w/ NZXT Kraken G10/x31 Corsair Vengeance LPX 16GB Samsung 850 EVO 500GB SSD/WD Blue 1TB HDD NZXT H440 | K70 RGB/SteelSeries Rival
https://linustechtips.com/topic/563280-fan-controller-for-msi/
nope :(
I think they have a mobile app called Command Center which is supposed to allow control from phones, but, according to review, it's buggy as hell.
I'm in a similar predicament with two MSI motherboards. It's annoying that MSI doesn't release an app.
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/563280-fan-controller-for-msi/#findComment-7408125
2 minutes ago, shadowbyte said:
nope :(
There is the Command Center, which does basically the same thing as Asus' overclocking/fan control software. Fan controls are less feature rich, but you get a RAMDisk which Asus doesn't have.
The app for your phone is basically a Wake On LAN client, to turn the computer on remotely. I've never used it, so can't comment on how well it works.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
https://linustechtips.com/topic/563280-fan-controller-for-msi/#findComment-7408156
you can control them in the bios
https://linustechtips.com/topic/563280-fan-controller-for-msi/#findComment-7408187
You can control the fans from within command centre program on the PC, it's not great for fan control TBH but personally I just set the fan speeds in the UEFI and leave it at that. So far had been good as I like a quiet PC, so have mine set at something like 40c 25% fan speed and ramps up from there when the temp does.. I also have my case fans set at around 50% which is lowest I think?? and so on... it's not as great as havign a proper fan speed controller in any way, and if I had one complaint I would like to see a bit more of an adjustment level, basically lower.. I mean why 40c?? I know that's not high at all, but would have preferred maybe 25c as the lowest setting, then anything under 25c would basically run off about 10% fan speed to still keep it cool and quiet. I do miss my proper fan controller I had as my PC was a lot quieter with it, but have to admit it was a PITA to have to remember to crank it up when you do some more intensive things with the PC.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/563280-fan-controller-for-msi/#findComment-7408201
