Hi guys
So i was wondering how is an OS made? it just blows my mind!
BTW: sorry if repost but i searched and didn't find something like this
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/56295-how-is-an-os-made/
https://www.youtube.com/watch?v=6MJUGVFAXKg
Here you go. Now let your curiosity be fed!
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-759694
with 0's and 1's
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-759696
with 0's and 1's
And Hello's to the world! :P
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-759698
with 0's and 1's
So with binary code. but in that do they whrite it?
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-759703
i dunno, im dumb :)
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-759721
There are 10 people in this world. Those that understand binary and those that dont.
Listen if you care.
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-759811
just write some c-code and compile it.
http://en.wikipedia.org/wiki/C_(programming_language)
- teamspeak.ltt-unofficial.com
- teamspeak.ltt-unofficial.net
- teamschnitzel.ltt-unofficial.com
- teamschnitzel.ltt-unofficial.net
cpu: Intel sandybridge-E 3930k @ 4.2Ghz
cooler: corsair h100 @ full speed push-pull
motherboard: Asus Rampage IV Extreme
gpu: 2x EVGA GTX660's & 1x EVGA GTX980
ssd: 2x samsung 256GB 840 pro raid 0
ssd: 1x samsung 1TB 840 evo
hdd: WD green 3TB
hdd: Seagate Barracuda 1TB (st1000dm003)
hdd: Seagate Barracuda 1TB (st31000520as)
psu: corsair ax1200i
ram: 8x 4GB corsair platinum @1866mhz
case: coolermaster cosmos II
age: Do the math (summer 2012)
monitors Main: 8x LG 22EA53 1080p 60hz
monitor Extra: 1xiiyama prolite G2773Hs 1080p 120hz 27"
os: windows 7 pro (64-bit)
keyboard: logitech g19
mouse: corsair m60
Lenovo T550
RaspBerry pi webserver:
Status: Offline.
Nas:
StatusOffline.
PC straight to the modem/router/switch/DHCP-Server/... with a 20cm (+-8inch) cat6a patch cable because same price as cat5.
ISP: Telenet (belgium)
Speed: 60Down-4Up (+- 45€/month)
ping to there servers: +-8ms
ping to other Belgians: +-12ms
- wheels for cosmos II
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-759839
My understanding:
The central component is the kernel. Usually written in something like C or C++. The kernel interfaces between the hardware and the software (applications, GUI, etc). The kernel should be able to control everything (firmware for the hardware, support for specific hardware, filesystem, etc). Beyond the kernel comes additional software layers to make things easier to control, like a GUI or terminal commands. There are other software components like API which allows for developers to create apps easier (subjective).
The other option you'd have is to re-package an existing OS. Linux is a good example of it, where a handful of operating systems are the father/grandfather of many others. Ubuntu is based on Debian, and Ubuntu spawned many more distributions. Usually, if you heavily modify a base OS, make your own modifications to it (GUI, pre-packaged applications, major kernel changes), you can re-package it as your own linux distribution, as long as you're able to support it as new kernel updates come in, and you provide the source code for the community to tinker around with. Custom Android ROMs are another example of this, most of which include custom GUIs and specific kernel changes.
Interested in Linux, SteamOS and Open-source applications? Go here
Gaming Rig - CPU: i5 3570k @ Stock | GPU: EVGA Geforce 560Ti 448 Core Classified Ultra | RAM: Mushkin Enhanced Blackline 8GB DDR3 1600 | SSD: Crucial M4 128GB | HDD: 3TB Seagate Barracuda, 1TB WD Caviar Black, 1TB Seagate Barracuda | Case: Antec Lanboy Air | KB: Corsair Vengeance K70 Cherry MX Blue | Mouse: Corsair Vengeance M95 | Headset: Steelseries Siberia V2
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-760431
lots and lots of cocaine mostly.. totally depends on the company creating it. lots and looots of lines of coke...
wow wow wow wait a minute is that how bil gates made dos?
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-760549
yup! it was a busy year for Billy Gates, he was also starring in Indiana Jones raiders of the Lost Ark, and directing the second mad max movie. Some say he also worked on the release of both Evil Dead and An American Werewolf in London. :P
Does anyone even use PCIe SSDs?
https://linustechtips.com/topic/56295-how-is-an-os-made/#findComment-760568
