Alright, so over the past few days I've been researching parts to build my first PC. I've used the website pcpart
icker.com and think (emphasize the think) I've done a pretty good job. But I'm sure there are things I could do better. With the help of the experienced people in this form I'd greatly appreciate it if you could help me make adjustments to my PC. Just so the forum dwellers know this PC is mostly for gaming but sometimes work. I want it to be as powerful as possible. I'm quite good at putting things to get her I just need to know what to put together. Or if it's all wrong just please help. The more opinions the better thanks. : )
Here is what I've come to, I've been aiming for around $1600 and under along with PC I need a keyboard and mouse. The color theme is white/black/blue. http://pcpartpicker.com/user/ThomasR13/saved/#view=JVGypg
https://linustechtips.com/topic/562771-my-first-pc-build/
8 hours ago, lolpwnd31 said:
permalink pl0x
i have a build plan similar to what you require at ~$1500 though, http://pcpartpicker.com/p/LBPRLk
you could skim off some of the price to make way for a better cpu cooler, and it fits your requirements
I changed it up a little. Thanks for the advice
https://linustechtips.com/topic/562771-my-first-pc-build/#findComment-7402902
