LQ Cooling Loop Help
Solved by givegomezthegun,
It doesn't really matter how the loop is run other than the reservoir has to feed the pump. In loops with multiple radiators many people will feed through a radiator before moving on to the next component to cool, but it doesn't actually matter. You could go from your pump to your video cards to your cpu then straight through 3 rads back to the reservoir, or pump to radiator to video cards to radiator to cpu to radiator to reservoir, it's up to you..
It starts with the reservoir and goes to the pump.. after that it doesn't really matter so long as it feeds back to the reservoir at the end.
