2 minutes ago, Bloxtonz said:
So. I am just about to buy my PC components, but I want to make sure that is it all good in the hood.
I DO NOT want a different case and I WANT to stay at a GTX 960
http://ca.pcpartpicker.com/p/7RN4K8 I would love to hear you advice and opinion!
Looking good!! The only thing I might do is start with an SSD installed so you don't need to migrate to one later.
Overall, an awesome build. I helped a friend build a system almost identical to this.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/560246-need-advice/#findComment-7373278
Just now, Bloxtonz said:
what is that?
What is what?
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/560246-need-advice/#findComment-7373307
6 minutes ago, Bloxtonz said:
what is that?
An ssd is a solid state drive, faster but pricier than an hdd. a 120gb ssd will hold the OS and basic programs. Most gamer and power users use them to speed up their systems.
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/560246-need-advice/#findComment-7373342
i would get a ssd
https://linustechtips.com/topic/560246-need-advice/#findComment-7373347
