hello everyone
My computer posts with normal beep sound but no display output
My setup is this :
Core i5 3570
Asus P8B75-V
2 x 4GB kingstone ValueRam cl9 at 1333 Mhz
Sapphire R9 280x vapor X "the 2 fans version not the newer 3 fans one"
CoolerMaster Extreme2 650w PSU
My monitor is a 19 inch Samsung S19B300 1366x768
No overclocking
it worked super fine till yesterday
when I hook the display to the onboard graphics it works like a charm like nothing happened
I don't know whether it's my graphics card dead or my psu
thanks in advance
https://linustechtips.com/topic/558665-computer-posts-but-no-display-output/
Might seem like a silly thing but did you check all the monitor cables? they can sometimes get loose, even months after plugging them in, causing some confusion.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
3 minutes ago, shehabxc72 said:
hello everyone
My setup is this :
Core i5 3570
Asus P8B75-V
No overclocking
thanks in advance
Can you boot into safe mode?
But it posts and he says onboard graphics work, so it definitely isn't the cabling.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
yes I tried another 2 HDMI cables , 2 Converters nothing at all
I edited the post "it works when I connect to the onboard graphics"
ok that would have been my next suggestion. try reseating the GPU (slide it out of the PCI slot, firmly push it back in) as well as double checking the power cables from the PSU and on the GPU (both ends of the cables).
If your graphics card has multiple of the input you're using for the monitor, switch to a different one. Make sure your graphics card is actually turning on with the rest of the machine (AKA not dead). Switch to a different PCIe slot. Try the card in a different machine if you have access to another.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
the card is posting with the system ..no double or triple buzzers ..the system posts normally and the fans of the graphics card are spinning normally ....I will try resetting the graphics card and try it in another in another rig but that will be tomorrow at a friend of mine as I don't have another rig available now
