Corsair Utility Engine - Scimitar RGB
Solved by Inheritance,
Just now, derick90 said:That actually brings up a good question, It's currently plugged into my 3.1 port, only other USB i've tried has been a USB 3, should i try one of the USB2 ports on my board? And no, it's plugged directly into the motherboard.
Go in ot device manager and delete everything under HID, and Mouses. Then try a 2.0 port. If that doesnt work try restarting with the mouse in a 2.0 port
ASUS loves to put special sauce on their 3.0 and 3.1 ports... And when i say special i mean they decide not to follow standards and shit goes wrong.
