3 minutes ago, CoolMaximus said:
Hi, I have the option of buying either the ax760w psu or the rmi 750w psu. Which one is better?
Between the two they are both excellent unit, your splitting hairs at this point but the main different with the RMi is the corsair link option if you want that kind of integration.
https://linustechtips.com/topic/556976-corsair-power-supply/#findComment-7334655
They're both great. Get whichever is cheaper for you (although the RMx is just as good as the RMi just without Link so I'd get that if it's cheaper).
https://linustechtips.com/topic/556976-corsair-power-supply/#findComment-7334670
