PC build - need help
Go to solution Solved by stealth80,
Just now, Firestrike said:
Because he will mostly use his PC for gaming, so no need for an i7, especially on a budget like this.
Except DX12 will prefer more cores and the OP wants the build to last 4 - 5 years. In addition the OP stated he has 800 - 900 USD for THE REMAINING PARTS, which gets a build like this:
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($374.99 @ SuperBiiz)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($104.99 @ Micro Center)
Motherboard: MSI X99A SLI PLUS ATX LGA2011-3 Motherboard  ($229.00 @ B&H)
Memory: G.Skill Ripjaws V Series 16GB (4 x 4GB) DDR4-2133 Memory  ($74.99 @ Newegg)
Storage: Samsung 950 PRO 256GB M.2-2280 Solid State Drive  ($181.95 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card  ($629.99 @ Amazon)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($118.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA P2 750W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($89.99 @ NCIX US)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($249.00 @ Amazon)
Total: $2103.78
Generated by PCPartPicker 2016-02-28 15:50 EST-0500
6 minutes ago, Andern said:
Wow yeah, completely missed that TI, thought that was way out of my budget, but i might be able to squeeze that in after all.
this is a tricky quesiton, but how long would you reckon a single 970 would last? while playing on best settings? as i'm thinking that maybe if the 970 would be enough for now, i could SLI/crossfire 2 of them in the future?
Firestrike, why would you recommend the H110i GTX instead?
I personnally would go for an H110i GTX, absolutely, because it's the same price and it's the most powerful AIO watercooler form Corsair, bigger, quieter because it's bigger so it doesn't need to spin as fast as the H100i GTX, and it cools way better.
|| CPU - i7 4790K @4.6GHz || GPU - MSI GTX 980 Gaming 4G || Motherboard - Asus Z97-A || RAM - 16GB Kingston HyperX Fury @1866MHz |Case Be quiet! Silent Base 800 ||
|| CPU Cooler - Cooler Master Hyper 212 EVO || Storage - Samsung 850 Pro 256GB & Seagate Barracuda 2TB (+ WD Caviar Green 2TB) ||
|| Mouse - Logitech G502 Proteus Core || Keyboard - Corsair K70 (MX Red) ||
get the 980ti, never set out with SLI in  system unless its 2x tops tier.
2x 970 > 980ti generally. however, they use more power and require SLI support in the game and generally the min fps is less than a 980ti.
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
