R9 Nano Help
Go to solution Solved by connorpiper,
Just now, HeroXLazer said:
What about maxed on 1440p
Depends on the game. Generally, my 980Ti can max out the settings at 1440p. Though some games like GTA: V cannot be maxed out.
Though usually High is not the much different from Ultra.
Yes.  It can run 4K as well.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/555749-r9-nano-help/#findComment-7322747
5800X3D - RTX 4070 - 2K @ 165Hz
https://linustechtips.com/topic/555749-r9-nano-help/#findComment-7322780
not at ultra and still get 60fps
https://linustechtips.com/topic/555749-r9-nano-help/#findComment-7322791
No single GPU can do that anyways.
https://linustechtips.com/topic/555749-r9-nano-help/#findComment-7322807
depends on the game
a 980ti can get 60fps ultra on over 90% of games
https://linustechtips.com/topic/555749-r9-nano-help/#findComment-7322829
