Wireless Standards WPA2-PSK
Guest
Go to solution Solved by blu4,
AES. Always.
Just wondering which one to use, either AES or TKIP
thanks
Thanks
6 hours ago, blu4 said:
AES. Always.
why? just wondering
What are you looking for?
3 hours ago, mcraftax said:
why? just wondering
It is not secure anymore due to vulnerabilities found in the algorithm. AES is still secure though.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Very interesting, thank you!
3 hours ago, Trikein said:
-snip
That only covered the TKIP part though
No, it covered WPA2 with AES. 2m35 seconds. Did you not watch the entire video? xD
k
