Tied between two builds....
Solved by 79wjd,
5 minutes ago, AwkwardKnight said:Care to say why? #2 was one someone recomended, #1 was my idea, so I'm just confused
The FX series is antiquated at best and offers similar performance to generations-old Intel CPUs. A locked Haswell i5 will outperform a heavily overclocked FX9590 in basically every scenario (other than certain virtualization tasks) let alone a Skylake i5, which will be about 10% faster than Haswell.
Plus the motherboard you chose for the FX8 can't properly handle that CPU.
