get an 860k instead
Edit: saw the price of the 860k compared to the pentium...
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/553143-first-build-ideas/#findComment-7294393
what aboot this
CPU: AMD FX-4300 3.8GHz Quad-Core Processor  ($147.99 @ Mwave Australia)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard  ($85.00 @ Umart)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1866 Memory  ($65.00 @ CPL Online)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($69.00 @ Centre Com)
Video Card: Asus GeForce GTX 750 Ti 2GB Video Card  ($189.00 @ Umart)
Case: BitFenix Comrade ATX Mid Tower Case  ($65.00 @ IJK)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($77.00 @ Umart)
Total: $697.99
Generated by PCPartPicker 2016-02-23 10:25 AEDT+1100
https://linustechtips.com/topic/553143-first-build-ideas/#findComment-7294396
3 minutes ago, the dell_tech said:
-snip-
if you have a micro-atx board get a micro-atx case in a non micro atx case your mobo will look lost
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/553143-first-build-ideas/#findComment-7294403
would i be better off getting a micro atx case now, and if i wanted to upgrade to a ATX board just get a better quality full ATX case
https://linustechtips.com/topic/553143-first-build-ideas/#findComment-7294413
I would get this:
PCPartPicker part list: http://au.pcpartpicker.com/p/XDrdpg
Price breakdown by merchant: http://au.pcpartpicker.com/p/XDrdpg/by_merchant/
CPU: AMD A8-7600 3.1GHz Quad-Core Processor  ($111.99 @ Mwave Australia)
Motherboard: MSI A68HM-E33 V2 Micro ATX FM2+ Motherboard  ($75.00 @ Mwave Australia)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($60.00 @ Centre Com)
Video Card: Gigabyte GeForce GTX 950 2GB OC Edition Video Card  ($235.00 @ IJK)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($69.00 @ IJK)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($79.00 @ PCCaseGear)
Total: $698.99
Generated by PCPartPicker 2016-02-23 10:28 AEDT+1100
beofre you ask , i used an a8 apu because it was the cheapest decent quad core i could find.
https://linustechtips.com/topic/553143-first-build-ideas/#findComment-7294420
4 minutes ago, Aytex said:
what aboot this
Total: $697.99
What kind of performance differences come from having a dual core intel vs a quad core AMD
https://linustechtips.com/topic/553143-first-build-ideas/#findComment-7294421
This?
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($95.00 @ CPL Online)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($71.00 @ IJK)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($79.22 @ Newegg Australia)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($71.00 @ IJK)
Video Card: Gigabyte GeForce GTX 950 2GB Dual WindForce Video Card  ($249.00 @ CPL Online)
Total: $711.22
Generated by PCPartPicker 2016-02-23 10:32 AEDT+1100
I chose a g3258 instead of a 860k because it is cheaper. in america they are usually priced very similar
https://linustechtips.com/topic/553143-first-build-ideas/#findComment-7294437
I would keep the micro atx and get a micro atx case if you want something small and are fine with the functions but changing motherboards could be a pain if you want to get a atx motherboard eventually just fuss up the money because it could be a pain in the ass to change. you would have to do all the cable management all over and if you had an oem copy of windows that would not be able to go over to the new board.
https://linustechtips.com/topic/553143-first-build-ideas/#findComment-7294453
I would spring for an i3 over a Pentium G if you are going for gaming. Some games can use the hyper-threading to their advantage and those that can are going to be very CPU hungry games to begin with.
I would try and save some cash by not going for flashy RAM and get something more basic.
As suggested, try to get a mATX motherboard unless there is a reason that you need a full size ATX.
Never used a high end AMD card so I can't say anything about NVidia or AMD. I guess it's a good card? I personally would go with a GTX 950 for a budget but someone can correct me on what the better of the two are.
Good HDD.
Good case? I think BItFenix cases have a reputation of having poor cable management at low price points.
Should be a good PSU, maybe get a non-modular 500W and deal with the cable clutter? Only difference would most likely be aesthetics.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/553143-first-build-ideas/#findComment-7294782
