Dual-channel is faster, right?
2 minutes ago, Mortis Angelus said:I have the choice of 1x 4gb 1600 Mhz CL11 and 2x 2GB 1600 Mhz CL11 memory modules. Shouldn't I use the 2+2 then instead of the single 4 gb?
Dual channel has twice the peak theoretical bandwidth of single channel. Quad channel has four times the peak theoretical bandwidth of single channel, and twice the peak theoretical bandwidth of dual channel. However, as you add more channels, efficiency decreases. With single channel being the most efficient (being able to hit its rated bandwidth nearly perfectly) dual and quad channel struggle to do so. My dual channel configuration, when heavily tweaked in every single timing, is only 98% efficient (I can hit 98% of my peak theoretical bandwidth) and quad channel tends to fall even shorter, topping out at around 95% efficiency.
In your specific case, dual channel with 2+2 would be a good idea, if you do not need more than 4GB of ram. Both are single rank, so you do not have the choice between Rank Interleaving and not, like you would if you were comparing 4GB vs 8GB.
