Complete audio setup -need help
Solved by Guest,
58 minutes ago, courtiousdoge said:4 headphones u can go with audio technica athm50x i can vouch 4 there quality becuz i hav them or u can go with custom 1 pros
55 minutes ago, courtiousdoge said:also take out mod mic and keep audio technica ag1 or game zero or go with hd 550 with mod mic
52 minutes ago, courtiousdoge said:senheiser game zero and hd550
Quite possibly some of the worst and weirdest suggestions I've seen in awhile.
For headphones, I would look at the AKG K553 or DT 770 Pro. Both have decent soundstage.
Schiit doesn't make any multi-channel gear, so Modi and Magni won't work with the Logitech.
