Posted February 19, 2016 So basically I've got an kraken x40 and it is really good at cooling my Fx 8350 @ 5ishGhz but it just doesn't look that cool so I want to build an completely custom loop but I'm not sure if the parts I have picked are compatible so basically I want you to tell me if it works or tell me to change anything, I'm a complete noob at custom cooling. Thanks Parts: EK-Supremacy MX WaterBlock https://www.scan.co.uk/products/ek-supremacy-mx-amd-waterblock-copper-base-designed-for-amd-socket-939-754-940-f-c32-am2-plus-am3-pl EKWB EK-XRES 100 Resiviour Pump Combo https://www.scan.co.uk/products/ekwb-ek-xres-100-ddc-mx-32-pwm-pump-and-reservoir-60mm-resevoir-diameter-100mm-height-(121mm-inc-pum EX240 120mm Radiator https://www.overclockers.co.uk/xspc-ex240-120mm-radiator-black-wc-084-xs.html EK G1/4 Threads (Buying 6, Extra 15% off if you buy 5 or more) http://www.ebay.co.uk/itm/EK-G1-4-Male-Thread-HDC-Fitting-12mm-OD-Nickel-/401026127246?hash=item5d5f05158e:g:vAAAAOSwZ1lWcq-K PETG Tubing (12mm) http://www.ebay.co.uk/itm/Barrow-2-x-Clear-PETG-Tubes-500-mm-Tube-Size-OD-12mm-14mm-16mm-For-watercooling-/171971887629?var=&hash=item280a52c20d:m:mmq2x1mQ9IR0quwhlJg7B_g Distilled water and Mayhems Dye https://www.scan.co.uk/shop/computer-hardware/all/coolers-water/cooling-fluid And I will buy everything else later such as the silicon insert extra fans and fan splitters, the cheap stuff. I thought about using a Kit and buying Hardline compression fittings and some PETG tubes but EKs kits are to expensive and Alphacools kits are all bay reservoir and I want to get a nzxt h440 and the h440 doesn't have any drive bays. I was using this from EKs Website https://www.ekwb.com/solutions/custom-loop/#needed-components Hope You Can Help. :-) My Current Build: FX 8350 @ 5Ghz || NZXT Kraken X40 ( 0-11'C Idle - 40-50'C Load) || Gigabyte GA-78LMT-USB3 || 4Gb HyperX Fury @ 1600Mhz / 3x1Gb Corsair XMS3 @ 1066Mhz || MSI R9 290 (Preforming At the Speed of an R9 290X) @ 1050Mhz || Cooler Master HAF 932 || 2x400Gb WD Drives - 500Gb Seagate Barracuda || 4 Random CD Drives || Viewsonic 1050x1680p Display || Logitech G602 Mouse || Microsoft Comfort Curve 3000 || Mpow Bluetooth Headphones || Next Build (April 2016): Same... || Custom Watercooled CPU loop || (October): Upgrade loop to include GPU || Laptop: Acer Aspire V3-531 || Intel B960 @ 2.2Ghz || 8Gb Ram || 500Gb Hitachi (donated from a old PS3 (120Gb Sandisk SSDNow Died)) || Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 19, 2016 you need a tower res in the H440 and EK's kits are actually alittle cheaper then if you were to get everything separate last time i checked Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 19, 2016 Author 1 minute ago, ITheSpazI said: you need a tower res in the H440 Whats wrong with the res My Current Build: FX 8350 @ 5Ghz || NZXT Kraken X40 ( 0-11'C Idle - 40-50'C Load) || Gigabyte GA-78LMT-USB3 || 4Gb HyperX Fury @ 1600Mhz / 3x1Gb Corsair XMS3 @ 1066Mhz || MSI R9 290 (Preforming At the Speed of an R9 290X) @ 1050Mhz || Cooler Master HAF 932 || 2x400Gb WD Drives - 500Gb Seagate Barracuda || 4 Random CD Drives || Viewsonic 1050x1680p Display || Logitech G602 Mouse || Microsoft Comfort Curve 3000 || Mpow Bluetooth Headphones || Next Build (April 2016): Same... || Custom Watercooled CPU loop || (October): Upgrade loop to include GPU || Laptop: Acer Aspire V3-531 || Intel B960 @ 2.2Ghz || 8Gb Ram || 500Gb Hitachi (donated from a old PS3 (120Gb Sandisk SSDNow Died)) || Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 19, 2016 don't forget you're gonna need a heat source and a silicone insert to bend that PETG tubing I would also probably think about a thicker radiator for some better cooling. What fans are you grabbing? you're gonna need a controller or PWM splitter from a motherboard header Ryzen Ram Guide My Project Logs Iced Blood Temporal Snow Temporal Snow Ryzen Refresh CPU - Ryzen 1700 @ 4Ghz Motherboard - Gigabyte AX370 Aorus Gaming 5 Ram - 16Gb GSkill Trident Z RGB 3200 GPU - Palit 1080GTX Gamerock Premium Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB PSU - Fractal Design Newton R3 1000W Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 19, 2016 Author 1 minute ago, stealth80 said: don't forget you're gonna need a heat source and a silicone insert to bend that PETG tubing I would also probably think about a thicker radiator for some better cooling. What fans are you grabbing? you're gonna need a controller or PWM splitter from a motherboard header I already have a heat gun and getting some corsair fans. they have like interchangeable colour rings. My Current Build: FX 8350 @ 5Ghz || NZXT Kraken X40 ( 0-11'C Idle - 40-50'C Load) || Gigabyte GA-78LMT-USB3 || 4Gb HyperX Fury @ 1600Mhz / 3x1Gb Corsair XMS3 @ 1066Mhz || MSI R9 290 (Preforming At the Speed of an R9 290X) @ 1050Mhz || Cooler Master HAF 932 || 2x400Gb WD Drives - 500Gb Seagate Barracuda || 4 Random CD Drives || Viewsonic 1050x1680p Display || Logitech G602 Mouse || Microsoft Comfort Curve 3000 || Mpow Bluetooth Headphones || Next Build (April 2016): Same... || Custom Watercooled CPU loop || (October): Upgrade loop to include GPU || Laptop: Acer Aspire V3-531 || Intel B960 @ 2.2Ghz || 8Gb Ram || 500Gb Hitachi (donated from a old PS3 (120Gb Sandisk SSDNow Died)) || Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 19, 2016 Not to rain on your parade, but you could have a nice i5 and motherboard for about the same amount as the loop and it will help performance much more. Then you could watercool that instead or just run it on air. Tip to those that are new on LTT forum- quote a post so that the person you are quoting gets a notification, otherwise they'll have no idea that you did. You can also use a tag such as @Ryoutarou97 (replace my username with anyone's. You should get a dropdown after you type the "@")to send a notification, but quoting is preferable. Feel free to PM me about absolutely anything be it tech, math, literature, etc. I'll try my best to help. I'm currently looking for a cheap used build for around $25 to set up as a home server if anyone is selling. If you are a native speaker please use proper English if you can. Punctuation, capitalization, and spelling are as important to making your message readable as proper night theme formatting is. My build is fully operational, but won't be posted until after I get a GPU in it and the case arted up. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 19, 2016 Author 16 minutes ago, Ryoutarou97 said: Not to rain on your parade, but you could have a nice i5 and motherboard for about the same amount as the loop and it will help performance much more. Then you could watercool that instead or just run it on air. Mum wont let me, I built my pc as my 14th Bday 'early present' this is for my 15th. anyway I think i5s are a waste of money. x99 is what I want to upgrade to. My Current Build: FX 8350 @ 5Ghz || NZXT Kraken X40 ( 0-11'C Idle - 40-50'C Load) || Gigabyte GA-78LMT-USB3 || 4Gb HyperX Fury @ 1600Mhz / 3x1Gb Corsair XMS3 @ 1066Mhz || MSI R9 290 (Preforming At the Speed of an R9 290X) @ 1050Mhz || Cooler Master HAF 932 || 2x400Gb WD Drives - 500Gb Seagate Barracuda || 4 Random CD Drives || Viewsonic 1050x1680p Display || Logitech G602 Mouse || Microsoft Comfort Curve 3000 || Mpow Bluetooth Headphones || Next Build (April 2016): Same... || Custom Watercooled CPU loop || (October): Upgrade loop to include GPU || Laptop: Acer Aspire V3-531 || Intel B960 @ 2.2Ghz || 8Gb Ram || 500Gb Hitachi (donated from a old PS3 (120Gb Sandisk SSDNow Died)) || Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 19, 2016 Just now, 13hanifz said: Mum wont let me, I built my pc as my 14th Bday 'early present' this is for my 15th. anyway I think i5s are a waste of money. x99 is what I want to upgrade to. Oh, alright. I'm not familiar with PETG tubing, so I can't really talk there. The rest of the parts should be fine. Still would not recommend a custom loop in this situation. What are your temps like now?Oh, and the rad you called a 120 is actually a 240. Make sure the dye has an anticorrosive and a biocide. Tip to those that are new on LTT forum- quote a post so that the person you are quoting gets a notification, otherwise they'll have no idea that you did. You can also use a tag such as @Ryoutarou97 (replace my username with anyone's. You should get a dropdown after you type the "@")to send a notification, but quoting is preferable. Feel free to PM me about absolutely anything be it tech, math, literature, etc. I'll try my best to help. I'm currently looking for a cheap used build for around $25 to set up as a home server if anyone is selling. If you are a native speaker please use proper English if you can. Punctuation, capitalization, and spelling are as important to making your message readable as proper night theme formatting is. My build is fully operational, but won't be posted until after I get a GPU in it and the case arted up. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
