is a higher clock better like on my cpu and gpu what is better to up and what is better to leave alone to get my maximum ppd as i get 3.3 k on my cpu
main rig: http://uk.pcpartpicker.com/p/GFvH7P
next upgrades. h440 . 8320.  possible liquid cooling AIO
https://linustechtips.com/topic/55011-higher-clock-speed-higher-better/
Typically a decent OC on the CPU is pretty safe. Can net you some extra PPD and as long as you do proper testing, you shouldn't have any issues. GPU's though, FAH is very picking with OC's on them. Everything can look to work but you will find things failing at 99% which is very frustrating. Most times even a mild OC on a GPU can cause WU failures. Set one up and test, but if you see failed WU's, will need to back down or even disable the GPU OC.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
  • 3 weeks later...
well i guess i've been lucky, i've got a 3570k ocd to 4.3ghz and my 7850 ocd to a 1 full ghz and never failed a wu. im only on 4.3 on my cpu to be safe, it his 40c here in summer and i dont know how my antec h20 920 will cope with that heat yet...
And then you realize your shoes are filled with peanut butter, what then?! >:L
