Project Mount - Postponed/CANCELED
Project Mount
Welcome to my first custom case build! This build will be using all parts that I have lying around my house and a few things I will be buying of course but I will be using as many things that I have. So, lets get going! :D
Purpose:
This system will be used to gold 24/7 and possibly mine if I get a good enough GPU for it.
Deadline:
There is no deadline as I will be doing this in my spare time. This project might not even start for a for weeks.
Components:
I don't know what most of the components are, but this will be updated ASAP.
Inspiration:
I saw the build called "MAXxPlanck V2" (click it!) and this made me think... if I made something like this, but air cooled? What advantages would I get in a open-air system like this? So here it is now!
Now to the main stuff!
I will try to update as soon as I can, but I can't guarantee it.
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/54896-project-mount-postponedcanceled/
You would get the disadvantage of dust.
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
Do we even get to know the specs?
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
What components are you thinking about putting in there?
i9 25.6 GHz with NeuronThreading, 256gb 6000 MHz RAM, GTX 990 OC 3024MHz 12gb, Skeletal X99 motherboard, 1 Petabyte SSD, Fractal Design Humaniod R1 Case, Herbivore 10,000W PSU, Noctua NF16 LP Derma Cooler.
Probably the only Star Citizen player who is planning on a career in Journalism instead of piracy, mining, trading, exploration, military, station management, etc.
Generation 0: The first time you see this add 1 to the number and copy it into your sig. Consider it a social experiment.
I am working on figuring out what the specs are, I know that the GPU is a 5500GT and a Pentium 4 CPU
BF4 should run smooth Haha!
Its not going to be used for gaming, it will be used for folding....
It was a joke...
It was a joke...
I know :P
That rig looks awesome, advantages I can think of are easy to change parts if you do that frequently, unique looks and probably very cool temps. 1 massive disadvantage: dust, tons of it. Also, nice WT1 avatar (I know that's not his channel name any more) :lol:
Go for it.. hope to see progress soon.
I will probably try to have a update out today
SSSSSSSTTTOPPP IT!
Update 1 - September 10, 2013
The preparations
Potatoes.
Update number one is finally here! Today I did some planning so here is what I have so far!
I will be using an old side panel for an old case, the sides will be bent to make the whole thing vertical and there will be acrylic panels added to the sides to add some space underneath.
Album:
The old PC
The beast of a GPU
The layed out plan
I will use a PCI extension cable to connect the GPU and all the cables will be routed under the whole thing.
Thanks for reading! :D
Any suggestions for a PCI (not PCI-E) GPU?
look for a Radeon 4650
Intel3570k  at  4.5ghz 1.300v  Noctua NH-D14    Gigabyte Gtx 970 G1   AsrockZ77 Extreme 6/TB4     Corsair8Gb vengeance memory    120GB Corsair Force SSD     1TB WD black      NZXT Switch 810
I have to unfortunately cancel/postpone the project as a few things poped up and I have a more urgent need.
