Hi I am thinking about getting a Vali 2 and a magni 2 is there a way I can switch between the two amps with out taking the cables out and put them in the other amp??
I want to try tube amp and I still want to have a normal amp, that is why I am thinking about getting both a solid and a tube amp.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/548956-help/
Is there any way I can split the signal from my pc out to the two dac so I only have to switch my headphone cable.....
https://linustechtips.com/topic/548956-help/#findComment-7250574
You can get an RCA splitter box/cable. Although, I have had grounding issues with similar setup. And you might also end up splitting the 2V signal, but that depends on the way the box (or cable) is build.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/548956-help/#findComment-7250612
something like this?
http://www.amazon.de/Splitter-Verteiler-Verbraucher-Tragbare-Elektronikger%C3%A4te/dp/B00HR5PXLW/ref=sr_1_5?ie=UTF8&qid=1455634964&sr=8-5&keywords=RCA+splitter
https://linustechtips.com/topic/548956-help/#findComment-7250662
or König Composite / Phono stereo splitter 1 to 4
https://linustechtips.com/topic/548956-help/#findComment-7250741
Just now, iShad said:
Why not just use virtualaudiocable to output to both at the same time? No need to buy anything.
well I cant connect them both to my pc with out buying something.
https://linustechtips.com/topic/548956-help/#findComment-7250766
what would you do if you wanted to connect two amps to your pc? and want to be able to just switch between them fast.
https://linustechtips.com/topic/548956-help/#findComment-7251460
2 hours ago, Dackzy said:
That's a switch. It takes 4 inputs and makes into 1 output.
You want something that takes 1 input and makes it into 2 (or more) outputs.
Yep, something like that: https://www.av-cables.dk/phono-splitter/composite-phono-stereo-splitter-1-til-4.html
But you should be able to find something cheaper than that.
https://linustechtips.com/topic/548956-help/#findComment-7251534
I dont think I can get them any cheaper in Denmark. Wow I think that it is the only model you can get in Denmark that is on the cheaper side...
https://linustechtips.com/topic/548956-help/#findComment-7251565
Just now, SSL said:
Get the Vali  and LISST tube if you really want to get both. I don't see the point, myself.
Well the point is that tube amps alot of times makes the sound a bit different and I would like to be able to switch between solid and tube so I can choose if I want the things tube does or I want normal solid.
Why is LISST tubes better than the ones that comes with it?
https://linustechtips.com/topic/548956-help/#findComment-7251710
Is that the point of tube amps? I thought it was to make things sound good. From what I've read at least, Schiit tube amps are generally pretty transparent.
The LISST is a solid-state tube. Get that and the stock tube and you can switch back and forth at will.
https://linustechtips.com/topic/548956-help/#findComment-7251719
Hmm I did not know that, but will the LISST work with a Vali 2???
https://linustechtips.com/topic/548956-help/#findComment-7251739
Just now, SSL said:
Would I recommend it if it didn't?
No.
Well okay then xD
So I can make a Vali 2 to a solid if I want hmm cool.
https://linustechtips.com/topic/548956-help/#findComment-7251746
