YES!
someone elso joins the CRYORIG H7 and Z97S Krait master race!!
welcome!
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/548724-first-build-parts-only/#findComment-7247859
Just now, shadowbyte said:
YES!
welcome!
OF COURSE! Had to go with the white cooler with the white/black motherboard! I also have hyperx fury white in there, as well as nzxt s340 white case :)
https://linustechtips.com/topic/548724-first-build-parts-only/#findComment-7247862
what i5 is that?
https://linustechtips.com/topic/548724-first-build-parts-only/#findComment-7247864
noice
you'll definitely get some nice ocs with that cooler
nice build!
https://linustechtips.com/topic/548724-first-build-parts-only/#findComment-7247872
Just now, Yames said:
List of all parts?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($224.95 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($123.98 @ Newegg)
Memory: Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1866 Memory  ($41.90 @ Amazon)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($319.99 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($64.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($48.99 @ NCIX US)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($249.00 @ Amazon)
Total: $1195.18
Generated by PCPartPicker 2016-02-15 21:20 EST-0500
https://linustechtips.com/topic/548724-first-build-parts-only/#findComment-7248005
3 hours ago, immanueltja said:
Very first yes.. Might need some help building it :(
The hardest part for me with my first build was the front wires, other than that everything fits like an easy puzzle. Feel free to post if you have trouble and someone/I might be able to help. Other than that it looks alright. Good choice on the 4 cores
https://linustechtips.com/topic/548724-first-build-parts-only/#findComment-7248057
I might message you for help.. I just have trouble with the front panel connectors as well. But I have an idea of how everything's going to work :), I'll message you right now.
https://linustechtips.com/topic/548724-first-build-parts-only/#findComment-7248086
3 minutes ago, FakeGhostPirate said:
for a first build I'd say key points are: read the manuals, use google/youtube for anything you're unsure of, and spend time on cable management, you'll thank yourself later
Of course.. I have watched many, and I mean MANY videos on building a computer. I think the most confusing is the sata/data cables and everything.. Plus my house is all carpet so I need to continuously ground myself
https://linustechtips.com/topic/548724-first-build-parts-only/#findComment-7248127
you're already WAY more prepared than I was for my first build (2009) so you'll probably have no problems.  I made mistakes and it still came out fine, you got this :)
https://linustechtips.com/topic/548724-first-build-parts-only/#findComment-7248147
