Help For A Friend...
Go to solution Solved by megadarkwood,
Answer above /\
No peripherals needed, just the PC, i'll post it in that section if i don't get any answers
http://pcpartpicker.com/p/1oAIL
Hi, Instead of me needing help with my system my friend needs help, He wants to build a system with the most performance he can with £300-£400 (mainly for gaming), He wanted me to post here as he wasn't sure if he was going to himself or not but i'm sure I/He will get a lot of nice helpful replies :)
https://linustechtips.com/topic/54842-help-for-a-friend/
Does he need a monitor, OS and peripherals?
We need to know this first
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/54842-help-for-a-friend/#findComment-736945
Totally off topic, but do you only have a laptop as your only computer?...
My Best 2013 Bitfenix Prodigy Build  Case: Bitfenix Prodigy White | Motherboard: ASRock Z77E-ITX | CPU: Intel i7 3770k | CPU Cooler: H100i | GPU: GTX 690
Fan Controller: Bitfenix Recon | Ram: Patriot IEM 16GB @ 1600mhz | Primary Storage: 2 x Samsung 840 Pro 256GB | Backup Drives: 2 x Seagate Barracuda 2TB | PSU: Seasonic X850
https://linustechtips.com/topic/54842-help-for-a-friend/#findComment-736953
Lol, yes I do. I am saving up to build a PC soon.
https://linustechtips.com/topic/54842-help-for-a-friend/#findComment-736959
Answer above /\
https://linustechtips.com/topic/54842-help-for-a-friend/#findComment-737024
Thank you, this is exactly what I needed, i'll show him tomorrow :)
No problem
https://linustechtips.com/topic/54842-help-for-a-friend/#findComment-737136
This is not under £400. Parts and prices vary from region to region.
Here you go: http://uk.pcpartpicker.com/p/1C0V9
Add a Hyper 212 Evo and ssd later down the road.
https://linustechtips.com/topic/54842-help-for-a-friend/#findComment-738390
