Hello LTT forum. I am having some issues with my upcoming build As you can see by the link down below is that I am going to buy Windows 8.1 64bit and Gigabyte does not have Windows 8.1 chipset drivers if anybody can help me that would be great. :)
Link: http://pcpartpicker.com/p/RNTJjX
                             Current PC Specs
                       GPU: 750ti CPU: AMD FX-6300 PSU: EVGA 500W Case: Corsair Carbide Series Windowed 100R Mobo: Gigabyte GA-970A-DS3P
https://linustechtips.com/topic/548347-i-need-help-with-drivers/
Just now, DaltonM said:
Why not go with an i3?
Because budget does not allow
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243938
I was looking at your build. And all I can say is just don't. If you build this pc, you'll have to buy new everything when you want to upgrade. This is a far more expensive solution in the long run. This PC you're building is already outdated, and with new CPUs and GPUs around the corner, not only will it become even more outdated, but prices will probably drop.
The '$500 gaming PC' myth is a plague on the PCMR.
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243947
CPU: Intel Pentium G4400 3.3GHz Dual-Core Processor  ($59.89 @ OutletPC)
Motherboard: Asus H110M-K D3 Micro ATX LGA1151 Motherboard  ($57.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($37.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: Zotac GeForce GTX 750 Ti 2GB Video Card  ($104.99 @ Amazon)
Case: Rosewill FBM-01 MicroATX Mini Tower Case  ($29.99 @ Amazon)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($29.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($45.00)
Wireless Network Adapter: TP-Link Archer T4U 802.11a/b/g/n/ac USB 3.0 Wi-Fi Adapter  ($36.65 @ Amazon)
Keyboard: Logitech K120 Wired Standard Keyboard  (Purchased For $0.00)
Mouse: Logitech M185 Wireless Optical Mouse  (Purchased For $0.00)
Headphones: Logitech H390 Headset  (Purchased For $0.00)
Total: $449.38
Generated by PCPartPicker 2016-02-15 11:26 EST-0500
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243948
Linus proved that Dual Core processors are not ready for GTA V and other games
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243958
I hope you're not trying to play GTA5 on that build.
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243962
Well this isnt about how outdated my parts are this is about drivers I
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243966
Agree but if you do push to build win 7 drivers sould work
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243972
That 6 core AMD CPU performs about as well as a dual core in gaming performance.
You can't get a CPU that games with a decent GPU for $500. No matter what you're getting throwaway parts at that budget. If you get like $300 more max you can build a beast PC that will last you years all you'll have to do is drop in a new GPU every now and then.
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243973
I was told by other people on the forum that My build that is linked can play GTA 5
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243975
A 750Ti? On low maybe.
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243988
Do you understand that I have a budget or not. Lets not turn this thread into a Intel vs AMD war
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243991
At the lowest settings on a low resolution. Sure you can play it at nearly xbox 360 quality but is that what you really want? It seriously detracts from the experience when it looks/runs like shit. People might say graphics don't matter, but when the game looks like ass and plays like ass they matter.
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243993
On Normal setting my freind has a build with the same CPU and GPU and he runs it at normal
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243998
I understand the budget, but I am resident LTT guy who tells people budget builds don't effin work. They're a waste of time. money.
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7243999
Listen buddy, My friend has a build with the same CPU and GPU (from a diffrent brand) And he runs it just fine
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7244004
Maybe it works. The point is your build is going to be outdated as soon as you build it. Make something else, something you came up with instead of making what your friend has.
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7244008
JFC! I try to ask you people nicely but all you give me is shit
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7244018
I DONT CARE IF ITS OUTDATED ALL I CARE IS THAT IT WORKS JFC
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7244030
Well since you said the drivers aren't going to work, then it's not going to work...
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7244036
Thats why I created this thread SO YOU GUYS CAN HELP ME FIGURE THIS OUT
Also
                             Current PC Specs
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7244050
here ya go assuming the version you have is 5.0 http://www.gigabyte.com/products/product-page.aspx?pid=4602&dl=1&RWD=0#driver
Also you can get a better case for about that price or a wee bit higher price...The case is not bad but there are better options...But if you already have it then that's fine, its not the end of the world (case can fit up to 11.60 inch gpu or 295mm, plus you can screw a 120mm fan to the side mesh :))
Don't call me a nerd, it makes me look slightly smarter than you
https://linustechtips.com/topic/548347-i-need-help-with-drivers/#findComment-7244067
