1 minute ago, derpyapple said:
Thats why I created this thread SO YOU GUYS CAN HELP ME FIGURE THIS OUT
Also
You're not expecting us to compile custom drivers for you with that attitude, are you?
We aren't Gigabyte, we can't help you besides tell you to choose a different setup, which you are clearly not willing to do. Since your friend has the same setup, ask him, I'm sure he'll be willing to help.
Also, calm your tits/balls.
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
Just now, DaltonM said:
The solution to the driver issue is to get different parts. I am merely suggesting that all your parts suck (expect for that GPU because I have a 750 ti lol)
Well then how about YOU try to put together a build for $400 and add a copy of windows for $45 and a wireless TP-LINK Archer T4U
                             Current PC Specs
                       GPU: 750ti CPU: AMD FX-6300 PSU: EVGA 500W Case: Corsair Carbide Series Windowed 100R Mobo: Gigabyte GA-970A-DS3P
I have already tried many times and the only solution I find acceptable is just to wait and save up more money to get a real PC that wont arrive to my door as an outdated garbage box.
Also you can get a mobo with wifi for less than the cost of a dongle boi.
I think you can easily just get a copy of windows free with a 10 dollar flash drive can you?  No need to spend $80+ on another copy of windows.....
Don't call me a nerd, it makes me look slightly smarter than you
Ok I calmed my balls, All I need is some chipset drivers and some audio. And no my freind is very stubborn and he didnt build the thing his dad did. Ill ask him.
EDIT- He is also running Windows 7
                             Current PC Specs
I have a USB stick what is this magical method to get it for free with a product key
                             Current PC Specs
Your mobo is a 5.0 revision (according to the amazon website that you are buying from) and I only found one chipset driver which is only a usb3 driver..
http://windows.microsoft.com/en-us/windows-8/create-reset-refresh-media
You can probably find mobo-agnostic Realtek drivers elsewhere for Win8/10 and the chipset drivers from another mobo with the same chipset should work.
2 hours ago, derpyapple said:
Hello LTT forum. I am having some issues with my upcoming build As you can see by the link down below is that I am going to buy Windows 8.1 64bit and Gigabyte does not have Windows 8.1 chipset drivers if anybody can help me that would be great. :)
Link: http://pcpartpicker.com/p/RNTJjX
There is 3 way you can install chip set driver or display driver: Hope below mentioned process help you;
before going to the method first i want to mention your chipset
AMD 760G + SB710 Chipset
North Bridge: AMD 760G
South Bridge: AMD SB710
1st way: Now days your driver get automatically installed if it is compatible with the OS you are installing, this automatic installation process
              happens during the installation of windows, you don't need to do anything
2 nd way : Using windows update.
       i) Open my computer
      ii) open system properties
     iii) go to device manager
     iv) expand display adapter by clicking the small triangle
      v) Some kind of diver will be installed by windows ( it is a basic display driver, made to show on the screen, but the quality of
        the image will be bad )
     vi) open properties of that driver
    vii) it will be on general tab , click on driver tab
   viii) click on update driver , than search auto, it will take some long time to search suitable driver for you , but it will automatically install it
If 1st and 2nd method fails you can try out this 3nd method i can't tell weather it is safe or not so please check for the virus in other PC with good AV and careful about false detection. For me both 1st , 2nd and 3rd method work.
3rd way :
      i) Check out this link and download the driver you want. :
     ii) Select the O.S you are going to install
     iii) From below download the driver you need
     iv) Save it on the drive in which you are not going to install OS , it will be better if you save it into some external source.
     v) After the installation of windows you are ready to install driver
     vi) if it is a exe file than ,than you know how to install exe file.
     vii) if it is not a exe file, if it is like this file ( scroll down the image for more details)
56c21b7ba6473_graphicsdriverfilename.jpg56c21b7f93e30_graphicsdriverfile.jpg.a7c
   viii) follow the step of " 2 way " from i to vii
    ix) now instead of auto select browse, and browse down to the file which content display driver, for ex : here i will select     graphics diver option (..\...\graphics driver) and then next
     x) if your OS think this driver is compatible it will install it.
