Is my audio solution good for now?
Solved by wyattzx,
3 minutes ago, gilm0re3 said:That's basically what I was expecting. I know onboard audio is never excellent, but I'm no audiophile, and theoretically upgrading the headphones will be much more of a noticeable improvement vs an upgraded audio output solution, right?
Depends on the degree of the headphones. If you pair a laptop with a pair of Sennheiser HD800s, the laptop will hold them back so much, that there would be no point, and upgrading the audio source would be mandatory. However, because your headphones are low-power, and they're not premium, high-end cans, they offer more of an improvement than your input setup. So yes, in this case the headphones outweigh the other end of the audio setup. However, a DAC + Amplifier will still go a long way.
