I just got my PC parts, and while trying to put it together, I noticed it wouldn't turn on. I assumed it was the PSU, and got a replacement right away. Same thing happened the second time, and now I was sure it was motherboard. I did a little googlefu, and saw a thread about jumping the power button with a flathead. Low and behold, the motherboard powers on. It seems to stay on (About five minutes so far as I write this.) but if I power it off, it stays off. Is it defective or what? I want to know if it's safe before I put any other pieces into it.
https://linustechtips.com/topic/547930-motherboard-issue/
the on switch seems to be defective, not the motherboard.
https://linustechtips.com/topic/547930-motherboard-issue/#findComment-7239537
If it doesn't turn on at all when using the regular method (AKA: the power button on your case) the problem might lie in the connectors for the the power button. I think that cable is together with the other F Panel connectors on your motherboard (typically in the bottom right corner of your motherboard).
Check with the manual to see if everything is plugged in correctly.
https://linustechtips.com/topic/547930-motherboard-issue/#findComment-7239550
