Does anyone know if a local repair place might have some rubber fan mounts? I checked websites where I am (which isn't like a big city or anything) and most of the places seem to just do repairs or sell prebuilt PCs. I need them for a project that I am doing and I would like to get them sooner than later as I am off of school this week and would like to finish while I'm off school. I have 8 cooler master sickleflow fans with the obnoxious "self-threading screws." I already painstakingly threaded every single fan hole once but it apparently wasn't enough. I attempted to put the fans in the case and I couldn't because of the awkward angle and that the screw head is actually wearing from my screwdriver making it near impossible to screw in now. Any suggestions?
https://linustechtips.com/topic/547892-rubber-fan-mounts/
Your best bet is online like Amazon, if your wanting to keep the screws but say have softer rubber washers you could getting o-rings from hardware stores.
http://www.amazon.com/Computer-Desktop-Anti-Vibration-Corsair-Alienware/dp/B014X49MWU/ref=pd_sim_147_2?ie=UTF8&dpID=51V5KIn9-zL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1E4N1X9810YV7P1H51WJ
https://linustechtips.com/topic/547892-rubber-fan-mounts/#findComment-7239235
You can probably get replacement screws from Cooler Master if the screws are stripped. Also, self tapping screws are the standard--just screw harder.
https://linustechtips.com/topic/547892-rubber-fan-mounts/#findComment-7241205
Repair shops rarely have special things like real rubber mounts. Or any spare parts for sale really. Online is best option. Or hardware store and get some o-rings. I actually like them better than pure rubber mounts. They do about same and are cheaper to replace once they aren't usable anymore.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/547892-rubber-fan-mounts/#findComment-7242673
