Hey guys,
I have noticed my CPU cores temperature on idle are 57oc and under load go upto 87-90oc. I am not even overclocking my i7 950 and it is at 3.2Ghz. So I wanted to liquid cool it so I can overclock it to 4GHz. My GPU temperature is normal at 60oc under load. So can anyone suggest liquid cooling for only CPU in an inwin 904 case.
Thank you.
P.S. - Also suggest Illuminations or LED setup please.
https://linustechtips.com/topic/547852-liquid-cooling-inwin-904/
you dont need liquid cooling to overclock it
you need to replace your thermal paste or buy a new cooler
an air cooler is more than enough
https://linustechtips.com/topic/547852-liquid-cooling-inwin-904/#findComment-7238769
