Can I create a fan speed curve to my case fans, just like in MSI Afterburner with the GPU? The fans are connected to the motherboard, not the PSU. The case I have is: Corsair Obsidian 750D. Here are a screenshot of SpeedFan: http://i.imgur.com/C07tMup.jpg
  •  CPU Intel Core i7-4790K @ 4.0GHz •  Motherboard MSI Z97-GAMING 5  •  RAM Corsair Vengeance Pro 16GB
 •  GPU MSI GeForce GTX 980 Ti •  Case Corsair 750D •  Storage Hyperx Savage 240GB & Seagate Barracuda 2TB •
 •  PSU EVGA 750W 80+ Gold •  Cooling Corsair H100i GTX •
https://linustechtips.com/topic/546262-case-fan-speed-curve/
Your case doesn't matter, your motherboard will always be where you go for fan control. MSI provides fan speed control from either your BIOS or from command center, which you can download and install from here.
https://linustechtips.com/topic/546262-case-fan-speed-curve/#findComment-7222913
16 minutes ago, Sakkura said:
Doesn't have to be 4-pin, that just determines if it uses PWM.
Isnt the only way to control 3-pin fans to change the voltage? And i dont know any motherboards that can do that
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/546262-case-fan-speed-curve/#findComment-7223143
Yep. You have to check on google for each particular model, it varies whether they offer fan control on 3-pin headers.
https://linustechtips.com/topic/546262-case-fan-speed-curve/#findComment-7223156
Thx, that worked, but can I make a curve that makes the fans go faster when my GPU is getting hotter?
https://linustechtips.com/topic/546262-case-fan-speed-curve/#findComment-7224667
Yes it is. But most modern (last 3-4gens) mobos can control fans via DC. Its not as accurate and fans can't go as slowly, but you still can do it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/546262-case-fan-speed-curve/#findComment-7225753
didnt know that, now i might have to unplugg my 3 pin fans from my trash fan controller to my motherboard just to see if it works
https://linustechtips.com/topic/546262-case-fan-speed-curve/#findComment-7225804
You will still need mobo software or Speedfan to do actual controlling. Some newer BIOS also do. But its same with PWM. You need to tell mobo that fans need controlling.
Newer board, better the support.
https://linustechtips.com/topic/546262-case-fan-speed-curve/#findComment-7225821
yeah, i believe my mobo has bios support for 3 pin fan curves if it supports 3 pin fan controling, because there is a built in fan programing program in my bios and my 4 pin fan curve i configured in the bios works great
https://linustechtips.com/topic/546262-case-fan-speed-curve/#findComment-7225853
