Hello,
I am interested in buying a new X99 motherboard to pair with a 5820k, and I was wondering the differences between these two motherboards:
ASRock X99M Extreme 4 MATX Motherboard: http://uk.pcpartpicker.com/part/asrock-motherboard-x99mextreme4
MSI X99A SLI Plus ATX Motherboard: http://uk.pcpartpicker.com/part/msi-motherboard-x99asliplus
I would like to know what features I would be losing out on (or even posssibly gaining) by going with the ASRock MATX motherboard.
Thanks in advance
https://linustechtips.com/topic/545844-x99-matx-vs-atx/
4 minutes ago, pappsicle said:
Hello,
Thanks in advance
The MATX board has 2 more Sata ports. The MATX board can only support 64gb of ram instead of 128gb. You also loose a few sun ports
i like trains 🙂
https://linustechtips.com/topic/545844-x99-matx-vs-atx/#findComment-7217869
the asrock has only 4 dimm slots, the msi has 8.
you are loosing expandability options, less usbs, but dual lan on the asrock.
It's up to you basically if you want more usbs and expansion slots or not
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/545844-x99-matx-vs-atx/#findComment-7217882
Both are good boards.
If you go with the ASRock, you lose
- 8 Total ram slots, as the ASRock only has 4.
- The MSI can support 3 way SLI I believe, while the ASRock only has 2 way
- The MSI has WAY more USB ports. Like a metric crap ton.
- The ASRock does not have any USB 3.1, so future proofing may not be as good
- the ASRock is colored, and may not match your build color
- both have M.2
Honestly, unless size is really important to you, I would just get the MSI one. Bigger and better, although the MATX board is still a good board itself.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/545844-x99-matx-vs-atx/#findComment-7217884
IF you are going X99 in mATX, then you should definitely check out the ASU X99m-WS:
http://www.amazon.co.uk/Asus-X99-M-Intel-2011-Motherboard/dp/B013WB33ES/ref=sr_1_1?ie=UTF8&qid=1455218440&sr=8-1&keywords=X99m+Ws
By far the best feature set for X99 in that form factor.
https://linustechtips.com/topic/545844-x99-matx-vs-atx/#findComment-7217989
23 minutes ago, pappsicle said:
Hello,
Thanks in advance
id get the MSI, more room to expand in the future and more ram slots.
you're not restricted to less.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/545844-x99-matx-vs-atx/#findComment-7218003
- both have M.2
Well im not sure if I will ever get 8 sticks of ram, and I definitely won't go 3 way SLI so the only things I would really miss out on would be USB ports?
https://linustechtips.com/topic/545844-x99-matx-vs-atx/#findComment-7218775
Unless you're dying for USB 3.1, then really the MATX board has plenty of spots for peripherals, you won't be needing like more than 4-6 USB ports I would hope, depending on what you actually do. I personally use 4.
iPhone 6
https://linustechtips.com/topic/545844-x99-matx-vs-atx/#findComment-7219686
Well I use 6 at the moment but the case would have 2, and the motherboard has 8 so I think I would be fine in that regard. Are there any advantages to USB 3.1?
https://linustechtips.com/topic/545844-x99-matx-vs-atx/#findComment-7222929
More devices in the future will start to use them, and it's quite faster, so it's very good for future proofing.
iPhone 6
https://linustechtips.com/topic/545844-x99-matx-vs-atx/#findComment-7223813
