Python Help
Go to solution Solved by Enderman,
both are right
in most programming languages you need to use the ()
not in python because its easy
so technically using () is unnecessary but does not affect the code or processing time at all
Hey Guys,
My teacher says that this is wrong:
if(example == "1"):
and this is right:
if example == "1":
Apparently I will get a lower test result because of "efficiency of code" or some shit like that. Is that true?
​Nothing Screams Professional Other Than Comic Sans
My Build: http://pcpartpicker.com/p/bQVfqs
Dark Theme, GG
https://linustechtips.com/topic/545822-python-help/
both are right
https://linustechtips.com/topic/545822-python-help/#findComment-7217520
It's the same thing.
It's just that the if statement in Python doesn't require parenthesis. Instead, they are used in expression delimitation. In your case , it is unnecessary, but at the same time doesn't make the code any less efficient neither at compile (interpret) time and even more so nor at run-time.
https://linustechtips.com/topic/545822-python-help/#findComment-7217541
2 hours ago, 8enjicraf2 said:
Hey Guys,
if(example == "1"):
and this is right:
if example == "1":
Both are accepted by the interpreter because parentheses are a valid way to group expressions and modify the order things are executed. Putting everything inside one set of parentheses is valid but redundant.
Whether or not someone think it aids code readability is more personal preference than anything. Personally, I don't think it adds any benefit to readability in the above example and would leave them out. This difference of opinion is why programmers in a team are often required to follow coding style guidelines. It helps keep the code more consistent.
Some teachers will give style guidelines but I expect most wont. If the class wasn't informed of style expectations then it seems unfair to have marks taken away for something like the above example (at least on the first offence).
There are certainly many languages that require the parentheses however there are also many languages that don't. Ex: Python, Ruby, Lua, Go, Swift, Rust, VB.NET, F#, Haskell, Elm, Perl (version 6), etc.
I expect it'd be valid code in most of them to use parentheses as well, but it doesn't mean that's how you should write them.
Not in python because its easy it was a language design choice to exclude them.
https://linustechtips.com/topic/545822-python-help/#findComment-7218959
Hello! As a fellow programming student I'm hoping I can shed some light onto why the instructor would actually take points off for this.
Lately we have been discussing a study (I'm sorry I haven't yet been able to find the link myself, so I cannot offer it yet) that shows that for a majority of "keyboard time" programmers are actually reading code. This could be for debugging reasons, or any other.
I believe that using extraneous markup could warrant a point deduction if for no other reason than it could potentially slow someone up who was reading it, and came across an unexpected character. There are also extra keystrokes, but I'm not about to wholeheartedly defend labeling two extra key presses as inefficient. I think the more pressing issue is to try to conform to standards that are widely accepted, if not required by a compiler/interpreter. In the case of Python that means you don't see parenthesis or brackets to the extent you would in a C-style language like Java.
We've always had it explained to us that in the perfect world of academia the expectations are sometimes significantly different than the requirements of real world development. In that particular case there is no need for the parenthesis, and since we are dealing with the "perfect world" scenario simply remove them. I believe madknight3 said it more succinctly, so I quoted their post in case mine was too long winded and rambling.
https://linustechtips.com/topic/545822-python-help/#findComment-7220502
