NEED HELP :P
Solved by DaltonM,
Just now, junaid_the_grenade said:well it really depends on how long it takes me to save up enough to get it
You can allocate some of your current budget, the cards will be out this year. I believe in creating an upgrade path rather than getting the most performance now. You can build a system that will last for years with only the need to update the GPU in the coming year(s). Anyway, I'm creating a build, stay tuned for it.
