Ok, so I am going to start off with the fact that I have been studying Python in school for about 2 years now (Year 11 in UK), and I have come across errors that have been frustrating me for quite some time now.
Here it is:
def welcomeScreen():
    #welcome message
    print("#####################")
    print("Welcome to Caroline's Painting/Decorating Company Program")
    print()
    #options menu
    print(" A | Enter employee details")
    print(" B | Enter customer details")
    print(" C | Estimation")
    print(" D | Price Calculator")
    print()
    option=input("Please select an input option: ")
    if option=="A" or option=="a":
        #enter employee details
        print ()
        print ("Employee Details")
        print ()
        for line in employeeInfo:
            employeeName,hireDate,birthdate=line.split(",")
        print("The employee's name is:",employeeName)
        print("The employee was hired on:",hireDate)
        print("The employee's birthdate is:",birthdate)
    elif option=="B" or option=="b":
        print("not implimented yet")
        welcomeScreen()
    elif option=="C" or option=="c":
        welcomeScreen()
    elif option=="D" or option=="d":
        welcomeScreen()
file=open("employeeInfo.txt","r")
employeeInfo=file.readlines()
file.close()
welcomeScreen()
the text document employeeInfo.txt looks like:
Dave Newman,11/3/03,1/2/1997
Jonny Stewart,15/12/15,22/5/1990
note, the welcomeScreen varibles inside of the elifs are just temporary, until I put code there :P
the error that comes up:
Traceback (most recent call last):
  File "Z:/Documents/Python/Exam Paper/Task 3/task 3-v1.py", line 45, in <module>
    welcomeScreen()
  File "Z:/Documents/Python/Exam Paper/Task 3/task 3-v1.py", line 27, in welcomeScreen
UnboundLocalError: local variable 'employeeName' referenced before assignment
Also, I need to put an input in there to get the user to input a name and have it check against the document, and I haven't been able to find a solution.
Thanks for your help!!
Future build:
http://uk.pcpartpicker.com/p/kGgNJx
Current build: (laptop)
Use the following style specs for your profile!
Specs:
Screeninator: Intel Graphics 5500
Stickaminator: Hyandai 12GB DDR3 RAM (1x8GB, 1x4GB)
Procrastinator: Intel i5-5500U @ 2.2 GHz
Noisoundacreator: TURTLE BEACH PX4
Remembrerthing: WD 1TB Blue HDD
Flat-Colorful-Thing: Samsung SyncMaster 2323Y
See-A-Move-O: Tecknet M288
https://linustechtips.com/topic/545194-need-help-with-python-program/
i dont have python installed to test myself, but i think its because this
is making local variables which cant be accessed by the elif statements outside the for loop
you need to make those things a variable at the start of of function welcomescreen and it should work
1 minute ago, madknight3 said:
The code worked when I ran it.
mine isn't working, using python 3.5.1
Future build:
Specs:
Just now, madknight3 said:
The only time I get that error is with an empty "emplyeeInfo.txt" file.
O.o I think the reason it was coming up was I hadn't saved the text file properly! whoops!!
Sorry about that, can you help me with the input though?
Every time I try and put one in it I keep getting errors
Future build:
Specs:
I would have thought that would be the case too but apparently it's allowed in Python. Still seems like a bad idea to me to do it though.
Can you post the code you're trying?
def optionA():
    print ()
    print ()
    employeeName=input("Enter the name of the employee you want to find")
    #welcome message
    print()
    #options menu
    print()
        optionA()
        welcomeScreen()
        welcomeScreen()
        welcomeScreen()
file.close()
welcomeScreen()
I know the input isn't doing anything there but I tried changing the "for line in employeeInfo" to "for employeeName in employeeInfo" but did not work so I reverted it
Future build:
Specs:
It's the normal way to write in Python since you can't declare a variable without initializing it like in other languages. Being forced to create a variable with some garbage value before a set of if statements that you know will change it is just a waste.
1474412270.2748842
When you're looping through the file you need to check if the employeeName is the employee you're looking for and if it is, break out of the loop. So first you'll need to change the name of one of your employeeName variables instead of overwriting the name you're looking for. Something like:
    searchName=input("Enter the name of the employee you want to find")
        #check if employeeName is equal to searchName:
            #break if it is
1474412270.2748842
