So, I got down to, that my pc case made a short on my motherboard (dont know why or how it happened)
Im now not willing to use the same case again, and im still waiting for some New cases that i like.
Does it harm my hardware to let the pc run on my motherboard box in the next few weeks, until ive bought a new case?
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/
No, it's totally fine. Just make sure you don't accidently hit it or something similar.
You'll also have to clean it more often, because dust can easily settle on it.
And please don't short anything out or spill water on your motherboard... But I guess you know that already :P
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203795
I was running my testbench like that for well over a year, so you should be fine (if your careful around it) ;)
[GUIDE] LGA 771 Mod for Dell Vostro 220 [GUIDE] LGA 775 BSEL Mod [BUILD] The Mighty Radeon-Powered Dell [VIDEO] Evolution of Intel CPUs
Can you game on an 8-year-old i7? Is the 4-year-old GTX 660 still relevant? Upgrading the HP Pro 3500
Main Rig:
CPU Intel Core i7 4930k @ 4.3GHz | Motherboard ASUS P9X79 Deluxe | RAM Hynix 32GB (8x4GB) 2133MHz CL11 | GPU Gigabyte GTX 980Ti G1 Gaming | Case NZXT Phantom 410 | Storage Samsung 850EVO 500GB, Seagate Barracuda 2TB | PSU Cooler Master G650M (650W) | Monitors x1 Dell U2515H, x2 Dell 1907FP | Cooling Noctua NH-D14 w. x2 NF-F12 iPPC-2000 PWM | Keyboard Logitech G610 ORION BROWN | Mouse Logitech Performance MX | OS Microsoft Windows 10 Pro x64
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203804
This is an excellent question. Overall it would kind of be like a test bench, which wouldn't be a big deal. Having the components out in the air like that wont hurt them, as long as your clean it regularly.
What i would be worried about is the box. Having that much hardware on a box that could catch on fire would freak me out. I don't think it would be an issue other than the box.
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203806
But how else do I watercool my motherboard!?
Yeah you'll be alright just be prepared for dust build up lol.
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203815
I've used a PC without a case for years. It's fine, just keep it clean.
、ヽ`ヽ`、ヽ``、ヽ`、ヽ`ヽ`、、ヽ`ヽ`、ヽ``、ヽ`、ヽ`ヽ`、、ヽ`ヽ`、ヽ``
、ヽ`、ヽ`ヽ`、、ヽ`ヽ`、ヽマッテェ(ノ;Д;)ノ `、、ヽ`☂ヽ`、ヽ``、ヽ`、ヽ`ヽ`、、
ヽ`ヽ`、ヽ``、ヽ`、ヽ`ヽ`、、ヽ`ヽ`、ヽ``、ヽ`、ヽ`ヽ`、、ヽ、ヽ`ヽ`、ヽ``
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203819
Yeah, but apparently something on my case felt different ?
Built  Not Bought
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203838
You probably already know the answer: it will technically work, but you have to ne really careful around your PC for this time.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203846
Well, my room is locked when im not home, and im living in my own apartment. So pretty safe. Also, the pc sits a bit away from me :-)
Built  Not Bought
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203847
Well, I dont have any light candles in my room or anything that would start a fire. Unless my pc is able to?
Built  Not Bought
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203854
Built  Not Bought
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203859
Seems good :D
Main Rig:
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203860
I mean, heat causes fire. Cardboard boxes are pretty good to burn. I dont think you would have an issue but i would be careful.
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203870
4 minutes ago, spartaman64 said:
it should be fine if you clean it often and be careful not to damage it. and btw did you install the motherboard standoffs in the case?
Ive been building pc's for at least 5 years (not impressed by it) thats the last thing i will forget ☺
Built  Not Bought
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203872
Thanks, i didnt know how it would act by longer use on the motherboard box :-)
Built  Not Bought
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203881
Yeah, im going to be too then :-)
Built  Not Bought
https://linustechtips.com/topic/544586-is-not-using-a-case-okay/#findComment-7203885
