I NEED HELP!
Go to solution Solved by ttam,
Please uninstall Rainmeter.
I have now idea as it was on standby
Download MalwareBytes, disconnect the computer from the internet and run a virus scan. If it doesn't help you will have to reinstall Windows. It looks like you got a virus on your hands
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/54441-i-need-help/#findComment-731399
