System crashing on game load!
Solved by FoxxyRin,
Dud PSUs can happen, so it wouldn't be unheard of. Your other PSU should be able to power the 980 Ti no problem with what all you have in your system. Try a different PSU and see if you're still crashing. If you are, then it's not the PSU and likely something else. It could also be a faulty GPU, or even just something as simple as over-heating. Try running your games in windowed mode on high settings and watch the temperatures. If it's getting hot, either you have bad cooling or a bad card, though I can't be sure with your PC, since I don't know how it's setup. If it's just shutting off for no reason and it's not the PSU, then I would RMA the GPU.
