I want to build my first PC. I was wondering if you guys can help me pick the parts. My budget is $300(not including windows!). I want to use this pc for games like minecraft and video editing. I am aware that this buget will not give me the poformence ill need. Thats ok because I just want a basic pc that able to be upgraded.
Thanks!
https://linustechtips.com/topic/543221-my-first-pc-build-help/
"Upgraded" is going to hurt you a bit imo. Most budget builds use AMD processors, but if you upgrade you'll want an Intel 1150/51 CPU, making you get a new motherboard (and maybe even RAM). Also, investing in something like an SLI mobo (or crossfire if you want to go AMD) will probably make your mobo a bit more pricy. If I were you I'd save up to at least $400 before buying anything.
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186027
If you could spend $100~150 more it will make a huge difference
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186050
1 minute ago, _LongJohnSilver_ said:
my parents wont allow  that
I tried!
Than wait, save up some more
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186067
1 minute ago, Aytex said:
id just buy a console, with that money
Noooo, don't mess up the guy dude
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186075
Thank you!
Just wait, don't rush it, took me a year to save up for the PC you see in my signature and you know what, i'm glad i did
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186090
7 minutes ago, _LongJohnSilver_ said:
Thanks! Do you know of a $400 build?
http://pcpartpicker.com/guide/fCZxFT/the-budget-gaming-pc-an-in-depth-guide-for-choosing-the-right-parts
Check out this PC build on pcpartpicker.  It comes to $464, but you can still save some by getting a slightly cheaper CPU cooler and only 4 gig of RAM (upgrade later).  You are NOT going to get a GREAT computer for this price, but it will get you gaming :)
|[ i7 6700k ][ MSI z170a XPower Gaming Titanium MB ][ 16gig G.Skill Trident Z 3000mhz ][ Gigabyte Xtreme GTX 980ti ][ Samsung Evo & Intel SSDs ][ Corsair 540 air ][ XFX Pro 750w Platinum ][ 24" Asus 144hz ]|
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186095
I play pc.
Thank god
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186101
P.S.  I believe you can get a copy of Windows (student version) through your school for around $60 - $80, or you could try Linux for free...
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186106
THANKS!
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186107
THANKS!
You are welcome.
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186118
This would be a start:
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($104.95 @ Amazon)
Motherboard: Biostar A58MD Ver. 6.x Micro ATX FM2+ Motherboard  ($41.98 @ OutletPC)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR3-1600 Memory  ($31.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($36.99 @ SuperBiiz)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  ($36.99 @ Newegg)
Total: $302.79
Generated by PCPartPicker 2016-02-07 15:18 EST-0500
I would also check your local classifieds to see if you can get a good deal on a used mobo and cpu.
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186141
Total: $302.79
I knew it, i knew someone was gonna post a build with an APU :P;)
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186196
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($98.89 @ OutletPC)
Motherboard: MSI 970A-G43 ATX AM3+ Motherboard  ($64.89 @ OutletPC)
Memory: Crucial 4GB (1 x 4GB) DDR3-1600 Memory  ($17.98 @ OutletPC)
Storage: Western Digital Caviar Blue 750GB 3.5" 7200RPM Internal Hard Drive  ($46.00 @ Amazon)
Video Card: PowerColor Radeon R7 370 2GB PCS+ Video Card  ($128.99 @ NCIX US)
Power Supply: SeaSonic 450W 80+ Gold Certified ATX Power Supply  ($59.16 @ SuperBiiz)
Total: $415.91
Generated by PCPartPicker 2016-02-07 15:25 EST-0500
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186210
or this, still a console KILLER :
CPU: AMD A10-5800K 3.8GHz Quad-Core Processor  ($124.86 @ Amazon)
Motherboard: Asus A88XM-E Micro ATX FM2+ Motherboard  ($66.49 @ OutletPC)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2400 Memory  ($66.99 @ Newegg)
Power Supply: SeaSonic 360W 80+ Gold Certified ATX Power Supply  ($57.99 @ SuperBiiz)
Total: $362.33
Generated by PCPartPicker 2016-02-07 15:33 EST-0500
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186259
Total: $362.33
What will Minecraft do with 16GB RAM, and what will @_LongJohnSilver_ do when his PSU burns his house down with not even a case to protect himself???
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186357
And the lack of a GPU. I mean, it has an APU, but APU+GPU and CPU+GPU is better. A single APU is a piece of ç)*[
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/543221-my-first-pc-build-help/#findComment-7186572
