1 click notifications
Solved by colonel_mortis,
Just now, Wolf_Lbh said:
Well maybe mobile mode has room for more that 1 icon at the top... Like perhaps the most common one, or the 7 most common ones... Lemme check... okay I found some room and made a diagram to help you locate where you could put a "select few" important icons, only about 6-8 or so.
Yeah, that is true. I'll pass the feedback on.
