Need help with strict budget build
Solved by EunSoo,
Was able to find parts for 120 except for a psu. Here:
http://m.newegg.com/Product/index?itemnumber=9SIA9AX3GK0305
Here is the cheapest 500w power supply that I found:
http://m.newegg.com/Product/index?itemnumber=9SIA85V3RA7733
I didn't check compatibility that much so you should probably make sure that they will all work. Also like a lot of other people, I would check eBay and Craigslist for cheaper parts (which you will probably find). Good Luck!
