Is Z170 chipset the best for overclocking a 6700k ?
System
CPU: Intel Core i7 5820K @4.5GHz - 1.230v  RAM: HyperX Fury DDR4 4x4GB 2666MHz  MB: MSI X99S SLI PLUS  CASE: NZXT H440  CPU-COOLER: Fractal Design Kelvin S24  PSU: Corsair RM1000W w/ white sleeved cable kit  GPU: MSI GeForce RTX 2070 ARMOR  MONITOR: LG 27GL850-B  STORAGE: Samsung 970 EVO 1TB M.2, Samsung 840 EVO 256GB,  WD Red 3TB
https://linustechtips.com/topic/542370-z170-for-overclocking/
Yes, it is.
I assume you'll aso want some help looking for a decent motherboard?
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/542370-z170-for-overclocking/#findComment-7177919
well yes, because you need it to be Z for overclocking and you need it to be 170 to support the CPU
https://linustechtips.com/topic/542370-z170-for-overclocking/#findComment-7177978
